Hi, I am trying to understand what is the importance of the "Break Detect" function when programming a microcontroller. Can some one tell me what it is useful for. here is a copy of it **************************************** void init(void) { P0M1 = 0x00; // push pull output P0M2 = 0xFF; ES = 1; // enable UART interrupt EA = 1; } void brkrst_init(void) // This function allows ISP entry through the UART break detect { AUXR1 |= 0x40; // enable reset on break detect SCON = 0x50; // select the BRG as UART baud rate source SSTAT = 0x00; BRGR0 = 0x70; // 9600 BAUD at 11.0592 MHz BRGR1 = 0x04; BRGCON = 0x03; // enable BRG } void UART(void) interrupt 4 { RI = 0; // clear receive interrupt flag }
From the comments, it seems as though this code is intended for a particular 8051 variant that has some built-in In System Programming (ISP) code. Apparently, when the UART detects an RS-232 break condition, it has the ability to reset the micro into the ISP download code. So, you'd attach your serial port to a PC, and reprogram the chip by sending a break, undoubtedly followed by the new code, as per the ISP method for this particular chip.
it seems as though this code is intended for a particular 8051 variant that has some built-in In System Programming (ISP) code Philips P89LPC9xx Erik
