Dear all, For some reason, I need to declare an array like that
#define STRING2_DESCRIPTOR_LENGTH 16 BYTE code product_string_descriptor[] = { STRING2_DESCRIPTOR_LENGTH, 0x03, 'U', 0x00, 'S', 0x00, 'B', 0x00, ' ', 0x00, 'H', 0x00, 'U', 0x00, 'B', 0x00 };
product_string_descriptor: DB end - $ DB 0x03, DB 'U', 0x00 DB 'S', 0x00 DB 'B', 0x00 DB ' ', 0x00 DB 'H', 0x00 DB 'U', 0x00 DB 'B', 0x00 end:
"I know in assembly, I can do something like..." So why not just do it in assembler, then?! If it's difficult in 'C' but easy in Assembler - surely the choice is obvious!! There is no problem linking 'C' & assembler in a single Project.
Hi Andy, The reason for me to post this question is that I think if I am able to do it in C, my strength is getting stronger than before. Just like when you are learning Mathematics, will you feel better if you know more than one solution for some questions than the other?
