Hi EveryOne, I received a file (firmware) with ".HEX" format to download in a STM32F103 (ZF). How can I convert this file in a format that I can use uVison + Ulink2? How is the procedure, step by step, on uVison?
HI, TKS FOR YOUR ATTENTION I don´t have the STLink 2, my device is a ULinK 2. Unless a big mistake the St-Link is not compatible with uVision, right? I understand that the problem is that the uVison need a complete project.
It's not well suited to the task. Get yourself an ST-LINK, and then download the firmware using the ST-LINK Utilities. If your board has USART1 connectivity, and control of the BOOT0 pin, you could use the Flash Loader Demonstrator application to download that way.
