Hi all... I am trying to interface SIM900A with 89S52 to send messages to the mobile phone. Code:
#include<reg51.h> unsigned char *command_ATE0 = "ATE0\r"; unsigned char *command_AT = "AT\r"; unsigned char *command_CMGF = "AT+CMGF=1\r"; unsigned char *command_CMGS = "AT+CMGS=\"+9199********\"\r"; unsigned char *message = "Welcome to the world of Robotics..!"; // Msg 2 be send unsigned char CTRLZ = 0x1A; void gsm(); void puts(unsigned char* ptr); void putc(unsigned char chr); void sendsms(void); void initialize(); void delay(unsigned int time); void main() { gsm(); while(1); } void gsm() { initialize(); sendsms(); } void initialize() { SCON = 0x50; /*SCON: mode 1, 8-bit UART, enable receive */ TMOD |= 0x20; /*TMOD: timer 1, mode 2, 8-bit */ TH1 = 0xFD; /*TH1: for 9600 baud */ TR1 = 1; /*TR1: timer 1 run */ } void sendsms() { puts(command_ATE0); delay(50); puts(command_AT); delay(50); puts(command_CMGF); delay(50); puts(command_CMGS); delay(50); puts(message); delay(50); putc(CTRLZ); } void puts(char* p) { char *temp = p; /*temp pointer so that the actual pointer is not displaced */ while(*temp != 0x00) { putc(*temp); temp++; } } void putc(unsigned char chr) { SBUF = chr; while(TI==0); /*Wait until the character is completely sent */ TI=0; /*Reset the flag */ } void delay(unsigned int time) { unsigned int y,z; for(y=0;y<=time;y++) for(z=0;z<2400;z++) { ; } }
but while stimulating the same in proteus, i am getting an error... the virtual terminal window display something ugly which i cannot understand. it displays something like @$#%%$#435#$5#$%GBF# %#^456y456%^%$% g$^&^&%$%^% can anybody please help me....
Wrong baudrate is a great way to get random junk printed.
By the way - what do you mean by:
You realize that the function gets a copy of the pointer as parameter?
can you also please let me know where do i need to change the code..... where i have made a mistake.... as i have seen... while working in a circuit... it sends the message correctly to defined phone number. but only gives error in proteus.... proteus baud rate also set to 9600....
