Hi I just upgrade may MDK 5.11 to latest packages but I face many error when select Ethernet interface (Phy DP83848C) using MDK-Pro it ask me for Ethernet API (KSZ8851SNL) and if I select that it show me error about SPI driver Keil::CMSIS Driver:Ethernet:KSZ8841SNL require 2.01:CMSIS Driver:SPI and no way to fix it I try to change packages use package select but no hope even STM32F107 example are not working is anyone have any recommendation or suggestion that may fix this By many thanks AL
This post is about network interfaces only but that application note is about all peripherals other peripherals seams works fine with application note but networks not!
For some reason, I did not saw that post above. Please do not be so jumpy - I meant nothing bad...
And what is the difference between your link to app note 266, and the link in the post directly above your?
Read this app. note:
http://www.keil.com/appnotes/docs/apnt_266.asp
tnx for replay I just check Application Note 266 (http://www.keil.com/appnotes/docs/apnt_266.asp ) but it won’t help with network interfaces(Ethernet for stm32f107 or PPP over serial) even for its own examples
Not sure if less creative use of !!!!!!!!!!!! and instead some time spent looking for other posts on this forum would give you some hint about the problem by looking at threads like: http://www.keil.com/forum/58371/
