Hello I try to use usb device library of uvision 5.11a but after setting ::USB:Device:HID to '1' in manage run-time environment , it shows this error message :
require 2.00:CMSIS Driver:USB Device .
But as i see , i have updated and downloaded cmsis and relevant software packs .
Please help , thanks .
Hello Armin,
most probably, you are using a device that has no CMSIS-Drivers available yet. Can you please specify which MCU you are using?
Kind regards,
Christopher
I'm having the same issue with an LPC1549. Where can I found out about CMSIS driver availability?
-Jeff
Hello Jeff,
there are no CMSIS-Drivers 2.0 available for the 1549. As for NXP only the 1800 series and the smaller parts of the 1700 series are supported.
