Hi all, I have a PK51 Professional Developers Kit version 6.14. When I build the target, it gives me the following error:
****************************************************************************** * RESTRICTED VERSION WITH 1000H BYTE CODE SIZE LIMIT; USED: 1A27H BYTE (163%)* ****************************************************************************** LINK/LOCATE RUN COMPLETE. 0 WARNING(S), 0 ERROR(S) *** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED MODULE: C:\KEIL\C51\LIB\C51S.LIB (-----) LIMIT: 1000H BYTES
Make sure that all modules are compiled with the unrestricted compiler. If any modules are compiled with the evaluation compiler, you may receive this message. Jon
