Hi, Maybe this is not the right forum for this question, but is there anyone who can tell me the correct settings to compile HID-firmware for the FX2? The problem is, I've written some firmware and it works on the development board. When I download the same HEX-file to our own board, the firmware won't enumerate properly. The difference between the development board and our board is that the development board has a 128-pins FX2, our board has a 100-pins FX2. I suspect it has something to do with the 100-pins FX2 not supporting external memory, but I can't seem to find any setting that will let me compile the source right for the 100 pins. Any help is greatly appreciated, Timo
"Why not try the forum at usb.org" Last time I looked there were two - make sure you go to the developers' forum (not the consumer one)! Definitely worth a visit.
Why not try the forum at usb.org. I have had a peek there now and then and, if/when I need to do USB, I'll definitely go there. Erik
Sorry for the confusion, I will explain a bit more. The FX2 is the cypress EZUSB-FX2 controller. It is a 8051 based USB controller. It comes in 3 different packages, 56-, 100, 128-pins package. This controller can communicate with a host PC through USB. This is controlled by the firmware. I am using it to create a USB-HID (Human Interface Device). The software I wrote works on the 128 pin version of the controller, but does not work on the 100 pin version. I suspect it is because of the memory setting in the BL51 Locate dialog of the Keil compiler. I have asked this question also on Cypress website, but as this problem will probably be solved with a different setting in the compiler, I thought I asked here. Again sorry for the confusion, I am working so much with this controller, I assumed (stupid me) everybody knows what I am talking about when I say FX2. Timo
C51: "HID-firmware" "FX2" Can you eleborate, I'm lost Erik
