I have four functions that the linker gives me the warning:
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?UART_RX_ISR_STUB?ISR *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?TIMER0_ISR_STUB?ISR *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?TIMER2_ISR_STUB?ISR *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?ASDC0_ISR_STUB?ISR
Steve, Maybe you could try forcing the functions into the overlay map by putting in dummy calls in a conditional block: if(0) { a(); b(); c(); d(); } If the compiler optimises it all out, do: unsigned char volatile x=0; if(x) etc Stefan
