hi,i am a newbie to c51,now i am am confused at this question that which rigisters must i push into stack when i call asm from c or call c function from asm,except the registers that i apparent used.be PSW?DPTR?else register else?
There is a section in the manual entiltiled, "interfacing 'C' to assembler" Have you read it?
The below apply to non-interrupt functions only am am confused at this question that which rigisters must i push into stack when i call asm from c or call c function from asm>/i> The compiler assumes NO registers saved, so an assembler function can blow every register with no ill effect. The reverse, assembler calling a C function, the assembler code must assume that the C function blow all registers. Erik
