dear all: In RTX-51 user's guide 09.97 page 25 ,there is a sentence: THE INTERRUPT ENABLE register of the 8051/MCS 251 are managed by RTX-51/251 and must not be directly manipulated by the user! but look this example : For example: #include <rtx51.h> #include <reg51.h> #include <stdio.h> #define STARTUP_TASK 0 //----------------------------------------------- //----------------------------------------------- void int0 (void) interrupt 0 { static unsigned int i; i++; } //----------------------------------------------- //----------------------------------------------- void task0 (void) _task_ STARTUP_TASK { os_set_slice (1000); /* Set for OSC Frequency / 10,000 */ EX0 = 1; /* Enable External Int 0 */ IT0 = 1; /* Edge-triggered */ os_enable_isr (0); /* Enable interrupt #0 */ while (1) { os_wait (K_TMO, 100, NULL); } } //----------------------------------------------- //----------------------------------------------- void main (void) { os_start_system (STARTUP_TASK); } Here why can diretly use "EX0=1"? What's difference between "EX0=1" and "os_enable_isr(0)"? Anybody can give me an answer?TKS! You may download this complete uVision2 application from the following URL: http://www.keil.com/download/docs/rtx51_ints.zip.asp
