I'm using uVision 5.14 and this is the error I receive when I try to use the '#message' directive:
error: #11-D: unrecognized preprocessing directive #message
Am I missing something?
Oh and BTW, my compiler is:
Armcc.exe V5.05 update 1 (build 106)
Where is it claimed that a #message directive is supported ?
Are you missing something? That depends on what expectations you have and what reference documentation you based your expectations on.
But you might consider:
#define CHARLIE #if defined(CHARLIE) #warning "Charlie was defined" #else #error "Charlie is undefined" #endif
"#warning" will give you a warning printout with your message text in the build log but will build the project.
*** Using Compiler 'V5.05 update 2 (build 169)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin' Build target 'Target 1' compiling main.c... main.c(4): warning: #1215-D: #warning directive: "Charlie was defined" #warning "Charlie was defined" main.c: 1 warning, 0 errors linking... Program Size: Code=312 RO-data=456 RW-data=0 ZI-data=608 ".\Objects\test-1768.axf" - 0 Error(s), 2 Warning(s). Build Time Elapsed: 00:00:00
While #error" will produce a compilation error with your text message:
Build target 'Target 1' compiling main.c... main.c(7): error: #35: #error directive: "Charlie is undefined" #error "Charlie is undefined" main.c: 0 warnings, 1 error ".\Objects\test-1768.axf" - 1 Error(s), 0 Warning(s). Target not created. Build Time Elapsed: 00:00:00
Exactly what are your needs for non-warning and non-error messages during the build?
My bad, I was looking at Cx51's, not ARM's documentation.
What I wanted to use the #message for is a status output indicating build's parameters. The difference between #message and #warning is mainly the intention: warning means there is something potentially wrong; message is more neutral. Plus warning output just takes more space in the build log.
I think the language standard only has #error
I think both #message and #warning are proprietary extensions - which, therefore, may not be supported.
