I just Started to work with CMSIS but when I Build a sample Code in my keil the following Error come up: core_cm3.c: error: C3900U: Unrecognized option '---'. I should mention that I have added the Drivers\include folder from CMSIS folder to include path option in my software but it seems it doesn't recognize some of the .h file that is located in that folder !!! Thanks
- what product version of Keil are you using? - whats the "Sample Code" you mention? - compare the "Options for Target - Linker - Linker control string" settings. probably an argument no more is supported or just missing after the characters '--'
Why just the Linker options?
There are also other places where arbitrary command-line options can be spcified ...
Without looking at the error code numbers, I must say that an error message that starts with the name of a C file sounds more like an error related to the compiler:
www.keil.com/.../armcc_chr1359124244999.htm
Thanks guys for your replies The Version of the Keil is 4.74. But I have found the problem it was related to the name of CMSIS folder that has been put. it had space and charachter '-'.
