Hello I am using LPC2000 flash utility for ISP programming to LPC 2214. crystal oscillator i am using is 4Mhz and baud rate is 4800. Actually it is very slow for one time programming it requires 10 min to upload my code, and using higher baud rate i am not able to upload the code. Can you please tell me how will increase the baud rate so that it will read my device.
http://www.keil.com/support/docs/3083.htm
If you were resourceful perhaps you could just download a smaller ISP loader of your own, get the processor into a maximal mode, and then use a faster baud rate and protocol to send the bulk of your code?
Which isp loader i should try, please can u tell me.
A resourceful Indian writes own?
Every time you have 10 minutes to waste, read the technical manuals, and code a better/faster method.
