Hello, I have to migrate from one type LCD to another. So, I cloned the project for the new LCD type. The problem is that almost identical code(software SPI) is compiled in very different manner.
Old project code:
//lS020: void SendData(WORD wrd){ BYTE i; Cs = 0; for (i = 16; i > 0; i--) { Dat = wrd & 0x8000; Clk = 0; Clk = 1; wrd = wrd<<1; } Cs = 1; }
compiled as:
47: void SendData(WORD wrd){ 48: BYTE i; 49: Cs = 0; C:0x3A7B C2A2 CLR PC2(0xA0.2) 51: for (i = 16; i > 0; i--) C:0x3A7D 7D10 MOV R5,#0x10 52: { 53: Dat = wrd & 0x8000; C:0x3A7F EE MOV A,R6 C:0x3A80 33 RLC A C:0x3A81 92A4 MOV PC4(0xA0.4),C 54: Clk = 0; C:0x3A83 C2A3 CLR PC3(0xA0.3) 55: Clk = 1; C:0x3A85 D2A3 SETB PC3(0xA0.3) 56: wrd = wrd<<1; C:0x3A87 EF MOV A,R7 C:0x3A88 25E0 ADD A,ACC(0xE0) C:0x3A8A FF MOV R7,A C:0x3A8B EE MOV A,R6 C:0x3A8C 33 RLC A C:0x3A8D FE MOV R6,A 57: } C:0x3A8E DDEF DJNZ R5,C:3A7F 58: Cs = 1; C:0x3A90 D2A2 SETB PC2(0xA0.2) 59: } C:0x3A92 22 RET
New project code:
//ILI9341: void TFT_SendData(WORD wrd){ BYTE i; Rs = 1; for (i = 16; i > 0; i--) { Dat = wrd & 0x8000; Clk = 0; Clk = 1; wrd = wrd<<1; } }
55: void TFT_SendData(WORD wrd){ 56: BYTE i; 57: Rs = 1; C:0x3AB5 D284 SETB PA4(0x80.4) 58: for (i = 16; i > 0; i--) C:0x3AB7 7D10 MOV R5,#0x10 59: { 60: Dat = wrd & 0x8000; C:0x3AB9 EE MOV A,R6 61: Clk = 0; 62: Clk = 1; 63: wrd = wrd<<1; C:0x3ABA 123578 LCALL L?0081(C:3578) C:0x3ABD EE MOV A,R6 C:0x3ABE 33 RLC A C:0x3ABF FE MOV R6,A 64: } C:0x3AC0 DDF7 DJNZ R5,C:3AB9 66: } C:0x3AC2 22 RET C:0x3578 33 RLC A C:0x3579 9285 MOV PA5(0x80.5),C C:0x357B C286 CLR PA6(0x80.6) C:0x357D D286 SETB PA6(0x80.6) C:0x357F EF MOV A,R7 C:0x3580 25E0 ADD A,ACC(0xE0) C:0x3582 FF MOV R7,A C:0x3583 22 RET
As as result I have 30% speed degrade.
Both projects settings are identical. I see no logic in such behaviour, and now I have to use assembler block instead. The question is: what happened and how to avoid?
Looks like you are optimizing for code size.
I suggest you change to OPTIMIZE(8, SIZE) as higher levels focus primarily on code size. See also here: http://www.keil.com/support/man/docs/c51/c51_optimize.htm
Thanks for answer, Reinhard. As I mentioned above the two projects have all identical settings. Changing optimization options does not help.
The compiler will only be able to reuse common code chains to reduce the code size if the code actually have multiple identical sequences of instructions.
Your first program doesn't.
Your second program does.
