Hi everyone,
I have a problem linking my application to an alternative start-address.
When I create a standard keil project, e.g. a simple LED-toggle program, I can set the base-address to another value in the tagret settings of the project an everything works fine.
But when I do the same with a cubeMX-generated project, the program does not even reach the reset-handler in debugging-mode.
I am pretty confused about that. Do I have to set anything else to another address, e.g. the interrupt vector table? In my understanding, the remapping stuff is done in the SystemInit() that is called from the reset-handler. But I don´t even get there...
thanks for any help.
Joerg
