Up until recently debugging worked fine. Now when I try to start debugging the debugger programmes the target, then verifies it, all of which seems to work, yet then suddenly the process fails with a "No ULINK device found" error message. I tried to decrease the max clock frequency value as well, which seems to have no effect at all.
Side effects: - In the Cortex-M target driver setup under "JTAG device chain" it says "No ULINK device found" as well, and there is no Adapter Serial No. either - When I try to start the debugger again, it seems to lag a bit. also between the "No ULINK device found" error message and the "Target DLL has been cancelled" error message there is a significantly longer delay. - When I try to reconfigure ULINK with "UL2_Configure.exe B0" sometimes it doesn't find the ULINK either, and when it does it returns this output:
ULINK2 Configure Utility V1.0
Disconnecting ULINK .......... Connecting ULINK Loader ..............................
Updating configuration ... Error: Communication failure!
Please note that the "Updating configuration step" always fails exactly after the third dot.
I am using Windows 8.1 inside VMWare Player 7.12 on a Ubuntu host system. and Keil uVision 4.74.
Any help would be greatly appreciated.
Don't think Virtualization is a qualified platform. Look deeper in to USB virtualization options/settings.
I strongly doubt that, since I haven't changed anything about the GPIO and the same code can be debugged without issues on other computers. I am currently forced to use a company laptop until I can resolve this issue, and the debugger works fine on there.
Is it possible that your code, when run, breaks the GPIO or debug interface, or puts the device into some low power mode causing the core to disconnect, or become inaccessible?
It seems that the next step, which fails, would be loading the object code.
