About the ARM RTX
I am adopting one of my previous application to use the ARM RTX. Now have some questions to seek your help.
Question 1.I have noticed that in the RTX_CM_Lib.h, there is a section of code:
#ifdef __MICROLIB
void _main_init (void) __attribute__((section(".ARM.Collect$$$$000000FF")));
void _main_init (void) {
  osKernelInitialize();
  osThreadCreate(&os_thread_def_main, NULL);
  osKernelStart();
  for (;;);
#else
__asm void _platform_post_lib_init (void) {
  IMPORT  os_thread_def_main
  IMPORT  osKernelInitialize
  IMPORT  osKernelStart
  IMPORT  osThreadCreate
  IMPORT  exit
  ADD     SP,#0x10
  BL      osKernelInitialize
  LDR     R0,=os_thread_def_main
  MOVS    R1,#0
  BL      osThreadCreate
  BL      osKernelStart
  BL      exit
  ALIGN
#endif
So it seems the _main_init already has called osKernelStart given the microlib would not be used as in my case. Then is it necessary to call them again in my own main function as suggested in the supplied code template:
int main (void) {
  osKernelInitialize ();                    // initialize CMSIS-RTOS
  // initialize peripherals here
  // create 'thread' functions that start executing,
  // example: tid_name = osThreadCreate (osThread(name), NULL);
        osKernelStart ();                         // start thread execution
Question 2 After I have chosen to use the CMSIS RTX via the pack manager, my program runs into the HardFault_Handler after this instruction in the code section mentioned in the question 1:
  BL      osKernelStart
Because it is well before the main function, I have no hint where the problem occurs. The STACK I assigned in the startup file is 0x4000. And other important RTX relevant setting are as below:
 #define OS_TASKCNT     3
 #define OS_STKSIZE     200      // this stack size value is in words
 #define OS_MAINSTKSIZE 250      // this stack size value is in words
 #define OS_STKCHECK    1
By the way, I don't quite understand what the exact relationship between the stack size in the startup file and the stack size in the RTX Setting file. Are all the RTX stack are included in the stack assigned in the startup file?
My application doesn't reside from the start of the internal Flash(0x8000000 for my CPU, STM32F105), but with a offset. I have modified the vector table in the system_stm32f10x.c:
#define VECT_TAB_OFFSET  APP_OFF /*!< Vector Table base offset field.
                                  This value must be a multiple of 0x200. */
And in the target setting tab. After a check of the generated hex file, I am sure all the code start from this offset.
The problem only occurs after I choose the CMSIS RTX component. My main function only adds these lines to the previous content:
#ifdef USE_RTX
  mut_Test = osMutexCreate(osMutex(mut_Test));
  tid_phaseA = osThreadCreate(osThread(phaseA), NULL);
  tid_phaseB = osThreadCreate(osThread(phaseB), NULL);
  tid_clock  = osThreadCreate(osThread(clock),  NULL);
  osSignalSet(tid_phaseA, 0x0001);          /* set signal to phaseA thread   */
  osDelay(osWaitForever);
#endif
If anyone has some hint about how to debug this HardFault, it would be very helpful. Thanks!
  • Some important additional information.
    1. I have single-stepped into the disassemble code and found VECTOR_TABLE is correctly configured before the section which would run into hard fault handler.
    2. I have modified the VECTOR_TABLE back to the start of the code address(0x8000000) and modify the flash range in the target setting tab. Then the program runs correctly with RTX. Could the CMSIS-RTX powered application be relocated as I have done? I suspects that whether the problem is caused by something relevant the SVC_Handler. I will report my result later.
