Hello i have managed to run uvision keil 420 through Wine on Ubuntu 14.04 the problem is that the editor does not work fine actually it is horrible; whenever you scroll down the code whit-spaces are filled with characters from the previous lines of code , besides these spaces and tabs are coloured with different colour that the editor's background colour.
is it possible to fix this problem ?
1. Wine is not a supported platform by Keil products 2. Linux is not a supported platform by Keil products 3. V4.20 is a former µVision version with an editor that is confirmed to be working well at typical requirements of a Keil product.
Note - the latest requirements we have summarized at: www2.keil.com/.../
So is there a way for a beginner to learn ARM Assembly if you don't use Windows?
Duh! Ever heard of the new fangled thing called the Internet?
There are masses of sites detailing it!
listen , if you don't like to share information so don't replay to others threads , understood !!
sure thing i googled before messing with wine and keil, found hints about sourcsry , QEMU and GNU Arm but as a beginner i was advised to to stick to keil+wine , Got it ??!
Ahem. I shared the most important information. It's not my concern that you can't use a search engine effectively. Even my 10 year old daughter can manage that task. I wonder why you can't.
And you really dug yourself a huge hole by taking note of such a rubbish piece of advice in using Wine.
Go fish.
Here's one link of many thousands: www.linux.com/.../805748-embedded-development-with-arm-mbed-on-linux
My Google search term was "embedded arm tutorial Linux". Try it, it's not difficult.
