Hi.
I have just downloaded MDK version 5 (uV5). My intension is to create i "bare-metall" (CMSIS included I assume, but no RTOS) application on an Atmel SAMD20(E17) uP according to page 17 on the document "Getting Started: Create Applications with MDK Version 5": " should be possible to select. But, no Software Components named "Device" is selectable from my list of choices. Only: "CMSIS", "CMSIS Driver", "File System", "Graphichs", "Network" and "USB". I then expand Software Component CMSIS, and select "CORE". Then, I'll get an error-message identical to the one shown at page 41:
-ARM::CMSIS:CORE Additional software components required --require Device:Startup Install missing component
Then I push the "Reslove" and "OK" button, but only file startup_SAMD20.s and a green square "CMSIS" (document link only) is seen in my project window/layout.
Q-1: Why is there no "Device::Startup" option on my "Manage Run-Time Environment" screen (nothing happends when I push "Resolve" and/or "OK" ...) Q-2: Have I missed some Software Packs (more downloads via the Pack Installer) ?
I'll appreciate assistance regarding these matters.
Best regards, Terje Bohler
Hello Terje,
this sound like you have not installed the Keil::SAMD20_DFP Pack. Can you please open Pack Installer and check that Keil::SAMD20_DFP is showing an Up to date button on the Packs tab?
Kind regards,
Christopher
