How the dhcp is set up
I am looking at C:\Keil_v5\Boards\Keil\MCB4300\RL\TCPNet\FTP_Demo\FTP_Demo.uvproj
The main code looks like below
extern LOCALM localm[];                       /* Local Machine Settings      */
#define MY_IP localm[NETIF_ETH].IpAdr
int main (void) {
  /* Main Thread of the TcpNet */
  init ();
  init_display ();
  init_TcpNet ();
  finit (NULL);
  dhcp_tout = DHCP_TOUT;
  while (1) {
    timer_poll ();
    main_TcpNet ();
    dhcp_check ();
    blink_led ();
Under dhcp_check() function, we are checking the MY_IP, whether it got the IP address after init_TcPNet() and main_TcpNet() are called in the main().
static void dhcp_check () {
  /* Monitor DHCP IP address assignment. */
  if (tick == __FALSE || dhcp_tout == 0) {
    return;
  if (mem_test (&MY_IP, 0, IP_ADRLEN) == __FALSE && !(dhcp_tout & 0x80000000)) {
    /* Success, DHCP has already got the IP address. */
    dhcp_tout = 0;
    sprintf((char *)lcd_text[0],"IP address:");
    sprintf((char *)lcd_text[1],"%d.%d.%d.%d", MY_IP[0], MY_IP[1],
                                               MY_IP[2], MY_IP[3]);
    LCDupdate = __TRUE;
    return;
I do not even see localm or MY_IP being passed as a parameter. Is localm declared as a global variable in the library and as a result of one of the calls (like init_TcpNet() or main_TcpNet()) localm (and MY_IP is getting modified?
Can someone please explain.. its confusing me a lot.
