Unhelpful Linker error message: L6218E?
Yes, I know about all the neophyte mistakes that cause the Linker to fail to find a symbol and result in L6218E error messages. This is not one of those cases. The error message (with non-essential parts x'd out) is:
.\_build\xxxxx_app.axf: Error: L6218E: Undefined symbol app_uart_init (referred from main.o).
So it's having trouble finding app_uart_init. But that symbol is indeed available, from a header file that is included in main.c, along with a bunch of other symbols that are found.
This symbol is a function name, with a fairly complex signature. My assumption is that the symbol matches just fine, but the linker is finding a mismatch between the declared signature and how the function is invoked in my code. But the L6218E error message is singularly unhelpful in this regard. Is there any way to get more info (e.g., in the Linker Map file) about what it thinks the specific problem is, e.g., which argument type fails to match?
I even went through the trouble of explicitly casting each of the actual function call arguments to the type specified in the function definition. Compiler was perfectly happy; didn't even issue a warning, but the Linker still failed. Sigh... Is there any way to diagnose this without going through all possible permutations of argument casting, etc?
TIA,
Mike
  • Signature? Casting parameters? Are you programming in C++? Because C doesn't use any name mangling for parameter types.
    By the way - why did you not specify any architecture? Didn't realize that different architectures uses different linkers?
    And another thing: You write "But that symbol is indeed available, from a header file that is included in main.c, along with a bunch of other symbols that are found."
    The header files are there for the compiler. They are irrelevant for the linker. When it gets time to link, you need that symbol available in an object file or a library that you have instructed the linker to care about.
