Address of xdata structure elements are not linked into code structure
I created a structure about data fields, which are located in a structure in xdata area. The informal structure itself should be in code area.
typedef struct
  unsigned char  *pucRamAddr;
  eNvmDevice      eDeviceId;    // enum type
  unsigned short  tNvmAddr;
  unsigned short  tLength;
  unsigned char   code *pucRomDefaults;
  char            ucFlags;
} TNvmBlock;
extern const TNvmBlock code tNvmBlock[NVM_BLOCK_COUNT];
Selected model is LARGE. Size of TNvmBlock is usually 11.
So pucRamAddr should point to the element within the xdata structure:
But after linking with BL51 at the pointer entry there is only the Offset within the xdata Structure, the added base address is missing.
I tried to define pucRamAddr as xdata pointer, but then the size of the struct was reduced to 10, although the pucRamAddr were still 2 Byte ???
unsigned char xdata *pucRamAddr;
The pointer target itself were defined like &(tStruct.Element)
Why doesn't the linker fill in the correct xdata address of the Element? And why schrinks the structure size somewhere else when I define the pointer as xdata * ?
