os_evt_wait_or(CHECK_EVENT_FLAGS, INFINITE_TIME); //Wait for an Event to occur rx_event = os_evt_get(); switch(rx_event) { case EVENT_INTERRUPT: if(chkflg) { dif = difftime(_gettime(), setalrm); if(!dif) *(tmp->flg) = 1; // on execution of this line (*tymval)--; if(*tymval == 0) chkflg = 0; } break;
the above code is a part of a task that sets a flag, whose address is passed in a structure using a mail box. dif is double. the alarm is generally set to 2 mins (120 secs) untill the dif > 1, things work well. when the dif = 1, the controller goes into hard fault.
i have read few articles and tried to follow the steps but could not come to any solution. www.ti.com/.../spma043.pdf
i use LPC17xx
