The 'sscanf' mistake
sscanf(buffer, "%d", &var1_1byte);
in the above case, var1_1byte is uint8_t (ie 1 byte char variable).
the "%d" in sscanf resulted to writing of multiple bytes (notice that '%d' is for 'int') which inturn cleared the adjacent bytes of ram at address &var1_1byte.
thus, var1_1byte, var2_1byte got modified. checking the .map file i confirmed the error and realized the mistake.
i used '%d' instead of '%c' so that ascii value in buffer is converted to integer (actually wanted to convert to hex).
Ignorant. (Sic).
luckily i could trace the error in not more than 5 minutes. a newbie may have consumed more time hence thought of bringing to the notice of others.
