Hi all, i'm experiencing an annoying problem with uVision 5: when I go into debug session and then go back to the edit session, the uVision 5 stays always on top and I can't switch between the other open programs. I must shut down the uVsion and re-open. Could anyone help me? Thanks in advance
Davide
Hi Christopher, I'm using uVision 5 under windows 7;
These are the other info:
IDE-Version: µVision V5.14.0.0 Copyright (C) 2015 ARM Ltd and ARM Germany GmbH. All rights reserved.
Tool Version Numbers: Toolchain: MDK-ARM Professional Version: 5.14.0.0 Toolchain Path: C:\Keil_v5\ARM\ARMCC\Bin C Compiler: Armcc.exe V5.05 update 1 (build 106) Assembler: Armasm.exe V5.05 update 1 (build 106) Linker/Locator: ArmLink.exe V5.05 update 1 (build 106) Library Manager: ArmAr.exe V5.05 update 1 (build 106) Hex Converter: FromElf.exe V5.05 update 1 (build 106) CPU DLL: SARMCM3.DLL V5.14.0.0 Dialog DLL: DCM.DLL V1.13.1.0 Target DLL: ULP2CM3.DLL V2.200.0.0 Dialog DLL: TCM.DLL V1.14.4.0
thanks for your support
Hello Davide,
which OS and which MDK version are you using? I have not seen such a behavior before.
Kind regards,
Christopher
