Hi all, i'm experiencing an annoying problem with uVision 5: when I go into debug session and then go back to the edit session, the uVision 5 stays always on top and I can't switch between the other open programs. I must shut down the uVsion and re-open. Could anyone help me? Thanks in advance
Davide
Hello Davide,
which OS and which MDK version are you using? I have not seen such a behavior before.
Kind regards,
Christopher
Hi Christopher, I'm using uVision 5 under windows 7;
These are the other info:
IDE-Version: µVision V5.14.0.0 Copyright (C) 2015 ARM Ltd and ARM Germany GmbH. All rights reserved.
Tool Version Numbers: Toolchain: MDK-ARM Professional Version: 5.14.0.0 Toolchain Path: C:\Keil_v5\ARM\ARMCC\Bin C Compiler: Armcc.exe V5.05 update 1 (build 106) Assembler: Armasm.exe V5.05 update 1 (build 106) Linker/Locator: ArmLink.exe V5.05 update 1 (build 106) Library Manager: ArmAr.exe V5.05 update 1 (build 106) Hex Converter: FromElf.exe V5.05 update 1 (build 106) CPU DLL: SARMCM3.DLL V5.14.0.0 Dialog DLL: DCM.DLL V1.13.1.0 Target DLL: ULP2CM3.DLL V2.200.0.0 Dialog DLL: TCM.DLL V1.14.4.0
thanks for your support
Maybe this uVision menu command helps: Window - Reset Windows to Defaults.
Does this solve the issue?
Hi Reinhard,
Thanks for your help, but this doesn't solve the problem. The only way it's to kill the IDE and restart
Hello David,
Sorry for bothering you for this minor issue. Is it possible to get mdkv5.05 now? I searched a lot but only the current v5.29 is available in the official website.
I am new to Keil so it will be a great help if you can show me some way.
You would need a licence to get older versions.
please don't hijack ancient threads with unrelated questions - start your own thread.
