I'm using the Cortex M0 edition with a Discovery STM32L053 board. I update all the packages needed, but when I want to copy an example from DSP_Lib , it failed ("Reason : Cannot create destination folder") . I started the Pack Installer in admin mode ...
img11.hostingpics.net/.../314547bug.jpg
Regards,
Yann
The PackInstaller does not require Admin rights to copy example projects.
The message that a destination folder cannot be created can be caused by: - destination folder has a name that is invalid - destination folder is write protected (or not enough access rights) - the root folder (i.e. driver letter) does not exist
If all this fails, check if you can manually create the folder using Windows Explorer (or command line).
Follow the below link: http://www.keil.com/support/docs/3718.htm
