STM32F3 Comparator hello everyone I am a beginner in STM32F3 and I found a problem with the comparator. I have no compilation error but its not working. If anyone can help me I would be grateful
here is the code:
COMP_InitTypeDef compp; GPIO_InitTypeDef GPIO_Inite; RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); GPIO_StructInit(&GPIO_Inite); GPIO_Inite.GPIO_Pin = GPIO_Pin_1; GPIO_Inite.GPIO_Mode = GPIO_Mode_AN; GPIO_Inite.GPIO_Speed = GPIO_Speed_50MHz; /* GPIO speed - has nothing to do with the timer timing */ GPIO_Inite.GPIO_OType = GPIO_OType_PP; /* Push-pull */ GPIO_Inite.GPIO_PuPd = GPIO_PuPd_NOPULL; /* Setup pull-down resistors */ GPIO_Init(GPIOA, &GPIO_Inite); GPIO_StructInit(&GPIO_Inite); GPIO_Inite.GPIO_Pin = GPIO_Pin_0; GPIO_Inite.GPIO_Mode = GPIO_Mode_AF; GPIO_Inite.GPIO_Speed = GPIO_Speed_50MHz; /* GPIO speed - has nothing to do with the timer timing */ GPIO_Inite.GPIO_OType = GPIO_OType_PP; /* Push-pull */ GPIO_Inite.GPIO_PuPd = GPIO_PuPd_NOPULL;; /* Setup pull-down resistors */ GPIO_Init(GPIOA, &GPIO_Inite); GPIO_PinAFConfig(GPIOA,GPIO_PinSource0,GPIO_AF_2); RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); COMP_DeInit(COMP_Selection_COMP1); compp.COMP_InvertingInput=COMP_InvertingInput_DAC1 ; compp.COMP_NonInvertingInput=COMP_NonInvertingInput_IO1 ; compp.COMP_Output=COMP_Output_None ; compp.COMP_BlankingSrce=COMP_BlankingSrce_None ; compp.COMP_OutputPol=COMP_OutputPol_Inverted; compp.COMP_Hysteresis=COMP_Hysteresis_High; compp.COMP_Mode=COMP_Mode_HighSpeed; COMP_Init(COMP_Selection_COMP1,&compp); COMP_Cmd(COMP_Selection_COMP1, ENABLE);
thank you in advance :)
