Hi all,
I am using RL_RTX Flash_FS . I follow the steps given in the Keil forum. i face some issues like this
C:\Keil\ARM\RV31\INC\File_lib.c(150): error: #5: cannot open source input file "FS_FlashDev.h": No such file or directory
I want the details for including files for Flash_FS, i include File_Config.c, RTX_Config.c, FSN_ARM_L.LIB.
Thanks in advance, K.Ganesh
So set up the paths in your project properly
C:\Keil474\ARM\RL\FlashFS\Flash\LPC_IAP_128\FS_FlashDev.h ?? C:\Keil474\ARM\RL\FlashFS\Flash\LPC_IAP_256\FS_FlashDev.h
I'm not sure that this will work at all for NXP devices. NXP uses ECC - single bit error correction with Hamming code. ECC works on a page of 16 bytes, but FlashFS needs to re-program units of 4-bytes.
So, when FlashFS tries to program additional 4-bytes in a page, which were left un-programmed (at 0xFF), ECC get's corrupted. The data which is read from that location, is also corrupted, because ECC tries to do it's work on data read. This prevents FlashFS to work from internal embedded flash on NXP devices.
