I am having a very frustrating time with Keil lately. I have create project using STMCubeMX that generates the configuration file for the STM32 Nucelo476 dev kit.
The problem I am having is that the Dynamic Syntax Checking will not work on my main.c. I get and error in the Error List window that says "Module Error! text completion deactivated." What is also confusing is that the first column of the Error Window has an 'F' which is not described in the documentation. Only an 'E' for error and 'W' for warning are talked about.
I have also dug through the forum and couldn't find any info.
Thanks for the help in advance, Tim
Any specific version of Keil or Windows? Anything remarkable about your system or the installation of Keil?
NO nothing out of the ordinary. I have been using uVision for other projects in the past and this is the first time it has happened, but also the first time I have use STMCubeMX to have the micro configuration.
