I need to understand the basic codes mentioned below.
I am a student, currently involving in the project where I am developing the software for MCU board. For that I am referring some sample codes to understand the basic structure before I write my own code. I have come across-ed several misunderstood.. those are below
uint8_t uartOutput = 1  ;
uint8_t data;
static u8 r_count=0 ;  //here what is u8 , r_count is a variable, static is the system code
#define ELEM_SIZE(array)        (sizeof(array) / sizeof(array[0]))
#define SEND_CAN_MSG(can_id, msg)       send_can_msg(can_id, msg, ELEM_SIZE(msg))
#define LOG(Format, ...) uartOutput && Printf(formt,##__VA_ARGS_)
particularly, I want to know how these codes will work and need explanantion for for each word in each codes. because I am totally unfamiliar with these syntax. Especially, I want to know,, what it is (need explanation) ? and why it is necessary to use ??
Thank you very much for your time
