Hi every one, There was a wide GPIO functions in the CMSIS initial versions which made easy setting and initialization of interrupts,like:
void GPIO_IntCmd (uint8_t portNum, uint32_t bitValue, uint8_t edgeState) Enable GPIO interrupt (just used for P0.0-P0.30, P2.0-P2.13). FunctionalState GPIO_GetIntStatus (uint8_t portNum, uint32_t pinNum, uint8_t edgeState) Get GPIO Interrupt Status (just used for P0.0-P0.30, P2.0-P2.13). void GPIO_ClearInt (uint8_t portNum, uint32_t bitValue) Clear GPIO interrupt (just used for P0.0-P0.30, P2.0-P2.13).
Above functions made easy enable interrupt for LPC1768 MCU,but know i want do same for LPC1788, I am using latest CMSIS version which does not support none of the above functions(there are only direction definition and read/writing functions). whats their alternative in the new versions?
These functions are actually provide by NXP. You should contact NXP to see if there is an equivalent for the LPC1788.
I also believe it is relatively easy to implement the functionality.
I searched around think I found something that you are looking for:
12/6/2012
http://sw.lpcware.com/
sw.lpcware.com/
select snapshot and it will download to your pc.
Really thanks dear friend,but above mentioned links are out of date,about 2012. in the latest CMSIS packages which i downloaded from KEIL packeges for LPC1788 there are last updated version which there are not that functions in it. WBR,Mahmoud.
