Hi I have installed the following tool: IDE-Version: µVision V5.16a Toolchain: MDK-ARM Cortex-M0/M0+ 256K for ST Version: 5.16a and it works good, but now How can I Install the toolchain Cortex M7 in lite edition ( size under 32K)? Best Regards M
There is a pack installer icon on the menu it has green, yellow and blue. Click on that to open up the pack installer.
On the right hand side select devices. Then open up STMicroelectronics then select STM32F7 series
all of these steps above are on the right hand side.
then on the left hand side select the packs tab.
and make sure
ARM:CMSIS Keil::MDK0Middleware Seil::STM32F7xx_DFP lwip::lwip worlfSSL::CyaSSL
are all installed and up to date.
if not click install.
Isn't the free one just for Cortex-M0 class ST chips? I doubt it will play well with M7 applications.
I'd strongly suggest putting a lite/eval version in it's own directory as it's likely to induce the fewest headaches, and give you some wiggle room to try/change things later.
