Hello, I would like to automatize my tests. For this, I am calling the Keil debugger via the dll. In my program I use debugger variables. The problem is that between 2 runs, already defined variables/breakpoints/watchpoints/functions are not cleared. I found how to remove watch and breakpoints, also functions. But, no way to remove a variable!? More generally, is there a way to be sure to have a clean environment? Delete project.uvgui.username????? (seems violent to me...)
Regards, Gelika
where exactly is a variable shown?
There are commands to remove breakpoints, variables from the watch windows, and a lot more. For example this: http://www.keil.com/support/man/docs/uv4/uv4_cm_watchkill.htm
We would need to understand what exactly is restored that you do not want?
HEllo, The variable is shown nowhere. I defined it using "DEFINE INT myvar" in the debugger command line window. I haven't seen any "window" where it is possible to see variables? Anyway, I'm not using the GUI, I'm calling Keil via the DLL with a python script (to automatise the tests)
