Will the current version of uVision run on windows 10? If not is there an update coming out soon?
Do you think normal end users knows when Keil releases new versions?
Are you sure that you shouldn't direct your question to Keil support? You can find links at the top and bottom of every page.
Download the Eval, and try it...
it works. and i know the older version 4.74a works too coz i use it.
but from when i upgraded to 10 my pc doesnt switch off properly. but thats not keils problem.
