HI, I am super confused why we need to use ttl to rs 232 conversion and rs232 to ttl conversion. please help...
They use different, incompatible, voltage signalling. Does your micro use CMOS or TTL logic? Are you transmitting your serial data over over long distances (>20cm and off board). Look at what the input and output thresholds are for each symbol state.
www.jade-cheng.com/.../ttl-rs232-voltages.png
Why wouldn't you use diesel with a gasoline engine?
If you have a board look at the schematic and find the uart connection to see if there is a translater chip in series with the microcontroller. If there is not then it would be ttl level. if there is then RS232 level.
Most logic-level signals are very weakly driven - both to conserve power and limit the amount of HF noise emitted.
So most logic-level signals are limited to short distances on the same PCB or in some cases maybe between two PCB boards with a very limited cable length between the boards.
To handle a bit longer distances, logic-level buffers may be used. This is common when interfacing medium-speed data between PCB. The buffer can supply higher currents but also often have rise- and fall-time limiters to reduce radiated HF energy. And the buffer normally has hysterese on the input to both support slow rise/fall times and to reject glitches from noise.
If the transfer rates are very high, then single-ended logic level can't be used any more, even for short distances between boards. So board-to-board communication normally need low voltage differential signalling (LVDS), where each digital line suddenly becomes two wires that flips polarity when the logic level changes.
For external cables, the amount of noise picked up can be quite significant. And also voltage differences beteen units that are separately powered. So RS-232 is a rather robust way to allow slow serial data up to about 15 meters. Logic level signal pins normally don't like that only one side of the connection is powered. This might break a chip. Or the unpowered chip may try to supply itself from the logic level input signal(s), which will put a significant load on the powered side.
So in the end, you normally always have specific buffer chips (often called transceivers since they transform transmitted and received signals between logic level and "long-distance capable" electrical formats) for signals leaving the PCB.
The RS232 standard require certain voltage levels your micro can not produce www.radio-electronics.com/.../signals-voltages-levels.php
