I'm working with uVision 5.15 and RL-USB with RTX to develop a USB CDC application. I used the function USBD_CDC_ACM_DataSend to send data over the USB com port. The application continuously (250ms step) sends a keepalive message through the USB com port to the host, the problem is that if the com port is closed after some messages the USBD_CDC_ACM_DataSend stops to work and also return 0 as byte sent, also opening the connection does not solve the problem. Someone knows how to solve this problem? Is this a RL-USB bug?
Regards
Sound like you are working on the old RL-USB using the latest MDK-ARM. The RL-USB interfaces and implementations had changed a lot at MDK ver5.0 USBD_CDC_ACM_DataSend() was replaced with USBD_CDC_ACM_WriteData()
Differences to RL-USB http://www.keil.com/pack/doc/mw/USB/html/usb_diffs.html
I remember we had discussed on a problem of the OUT (host->device) endpoint at buffer full in the CDC of the old RL-USB. www.keil.com/.../ I'm not sure, the IN (device->host) endpoint would also have any problem.
Maybe your PC is a Linux (or Mac) box, which polls the CDC bulk IN endpoint just while the COM port opens. Windows CDC driver always polls the IN endpoint, regardless of open/close of the COM port.
A couple of workaround suggestions, a) Endpoint status Your firmware may read out the endpoint status directly from the USB hardware register. This method depends on your MCU, tell us the type number of your MCU for further discussion. While the IN endpoint is still occupied by the last packet, don't call USBD_CDC_ACM_DataSend().
b) DTR signaling to know open/close of COM port In most of OS, PC serial library raises DTR at COM port open, it drops DTR at close. If your library wouldn't, your PC application could explicitly flip DTR signaling at open/close. Your firmware can catch DTR change by USBD_CDC_ACM_PortSetControlLineState() callback. While DTR drops, don't send the heart-beat message.
Tsuneo
Hi Tsuneo! How can you set the control line for USBD CDC? I've asked similar questions https://community.arm.com/developer/tools-software/tools/f/keil-forum/47289/lpc1768-architecture-questions . I'm working with the VirtualCOM USBD sample for lpc1768, I can connect to the PC but can't seem to read data that I send from the MCU to the PC in C#. I can however, using teraterm. Any hints at what might be wrong?
Kev said:can't seem to read data that I send from the MCU to the PC in C#. I can however, using teraterm
Check your control signal settings - DTR, RTS ...
You could also use something like https://www.eltima.com/products/serial-port-monitor/ to see what's happening at the PC end - and where you C# differs from Teraterm ...
EDIT
I'm not affiliated with nor sponsored by Eltima - but I have used their Serial Port Monitor with success in debugging such things.
