printf corruption while called in a sunroutine with inrelated interupts running
I'm having a major problem with printf. The code is set up so that the printf's are used in subroutines, 1 maybe 2 deep. There is a separate RTC routine running that has nothing to do with the printf subroutines.
Here is the problem,
if the interrupt is off printf works OK,
if the RTC interrupt is running, the printf prints a few characters correctly then takes off in an endless stream of garbage, but repeating pattern. The printf never returns once this starts.
Here is what has been done,
printf's pointer requirements have been minimize by breaking complex lines into separate lines
RTC interrupt rate has ben reduced, in case there was a cpu speed resource issue
Xdata ram reserve has been increased to 700 bytes.
I suspect there is some sort of ram conflict occurring, but I am having no luck in figuring it out. Has any one seen the printf source code.
The only solution will be to write a totally new printf, but this si a big job with teh format specifiers and there is likely not enough memory.
any help appreciated
