I'm trying to set up a PPP link over a BGS2T (Cinterion) modem with the Keil PPP Middleware. I managed to get up until the LCP and CHAP phase of the PPP connection but then the PPP suddenly stops and sends the Terminate command. From the trace I can see everything is ok up until the IPCP "configuration request" frame. After this a LCP "terminate request" is send and the session is terminated.
I have no clue why this happens and how to resolve it. What are common reasons to terminate an IPCP config request?
Many thanks
Gerrit
Don't know, but would suspect such things might happen with deprecated/compromised/weak protocols/versions/options are selected/requested.
If you're not connecting into something you control, and can see the other side of the transaction, consider doing so.
