Hi, i have a problem about how to implement the stepper steps in C or C++ programing..the question is in below...please some one help me to do this project greatly appreciated...
Project Description: Using an external potentiometer and stepper motor/driver, drive the stepper motor through speeds full-reverse through full-forward and display the current potentiometer input voltage in the Debug Viewer.
and the another i am confusing on this one... Can you use ADC1 to measure the Vbat signal on the board without additional wiring/hardware? If so, provide the code required to accomplish this. If not, provide justification.
Nothing specifically to do with Keil or ARM or STM32 - you must understand what you need to do before getting into the details of how to implement that using specific tools & devices...
homepage.cs.uiowa.edu/.../
Presumably your coursework should have prepared you to do your own homework? If not you should talk with your instructor, who might be able to provide additional insight, or study materials.
Yes, you should be able to measure VBAT on an STM32F4 device, though you'd need to know what your primary supply is.
the it is in STM32F407VG....
