WHEN I COMPILE USING PROTEUS KIEL 5 THE PROGRAM SHOWS ERROR L121:IMPROPER FIXUP . WHEN I DELETE INTERRUPT 2 THE COMPILER COMPILES SUCESSFULLY. HELP PLESE ANYONE. can anyone tell me what is wrong with this sour #include<reg51.h> sbit op1=P2^7; sbit op2=P2^6; unsigned char data byt=0xFF; void keydly() { int a,b; for(a=0;a<50;a++) for(b=0;b<1000;b++); } void delay1ms(int d) { int k; TL0 = 0x17; TH0 = 0xFC; TR0 = 1; for(k=0;k<d;k++) { while(TF0==0); TF0 = 0; TL0 = 0x17; TH0 = 0xFC; } TR0 = 0; } void delay50ms(int c) { int p; TL1 = 0xAF; TH1 = 0x3C; TR1 = 1; for(p=0;p<c;p++) { while(TF1==0); TF1 = 0; TL1 = 0xAF; TH1 = 0x3C; } TR1 = 0; } void gripopen() { int x; for(x=0;x<4;x++) { op1=0; delay1ms(4); op1=1; delay1ms(20); } } void gripclose() { int y; for(y=0;y<4;y++) { op1=0; delay1ms(1); op1=1; delay1ms(20); } } void gripclk() { int w; for(w=0;w<4;w++) { op2=0; delay1ms(4); op2=1; delay1ms(20); } } void gripaclk() { int z; for(z=0;z<4;z++) { op2=0; delay1ms(1); op2=1; delay1ms(20); } } void gripup() { P2=0x01; delay50ms(20); P2=0x00; } void gripdwn() { P2=0x02; delay50ms(20); P2=0x00; } void rotetleft() { P2=0x04; delay50ms(40); P2=0x00; } void rotetright() { P2=0x08; delay50ms(40); P2=0x00; } void int1() interrupt 2 { byt=P1; EA=0; keydly(); } void main() { TMOD = 0x11; P2=0x00; P0=0x00; op1=1; op2=1; P1=0xFF; back: IE=0x84; byt=0xFF; while(byt==0xFF); switch(byt) { case 0xF1: gripopen(); break; case 0xF2: gripclose(); break; case 0xF3: gripclk(); break; case 0xF4: gripaclk(); break; case 0xF5: gripup(); break; case 0xF6: gripdwn(); break; case 0xF7: rotetleft(); break; case 0xF8: rotetright(); break; } goto back; }
