I would like to use uVision 5.15 in order to develop an appliaction on MSP432. I was not able to find the TI.MSP432 pack on the download page from KEIL.com so I tried through the pack installer within the software.
I receive then the message: Cannot install Pack(TI:MSP432), Pack not found
Do you know where can be located this pack or what should I do to be able to download it?
Thank you and regards,
Antoine
Hello Antoine,
the best way to install a Pack is to use Pack Installer directly. If you select the device you wish to use on the Devices tab, you can click on "Install" on the Packs tab which will download and install the Pack automatically.
Kind regards,
Christopher
Thank you Christopher for the answer, Unfortunately this feature seems to be defective for the MSP432:
I received an error message indicating "pack not found"
However it works nicely with the external download,
Regards,
