3.3V supply for ttl/rs232
I find a problem when I wanted to run a ATMEGA32 with VCC supply of 3.3V, everything is okay except USART. I see that if supply voltage is 5V then USART works well. With the same ttl/rs232 module and supply voltage of 3.3V USART works fine with STM32 MCU. I used internal 8 Mhz clock both for AVR and ARM. what is the suggestion to overcome the problem in AVR?
