I created a table, where I have various data. I need to take out data from this table, alter it, then write it back to the same position, however, for some reason, data is not written to the position
Here is my code
CSEG AT 3h table: DB 100, 200, 150, 170
Lookup: MOV DPTR, #precos ; DPTR points to the start of the lookup table MOV A, #0 ; A is the offset from the start of the lookup table MOVC A, @A + DPTR ; Moves the (A+1)th item into the Accumulator ADD A, #20 MOV R1, #3 MOV @R1, A JMP Lookup
When I loop through the code, A goes from 0 to 100 to 120, then it's supposed to write it at position 3, get it back again, add 20 more, etc...
What I actually need, is a way to access a memory position, alter it, then update it.
The 8051's CODE space is read-only !!
This is fundamental to the 8051 architecture - there is no instruction to write to CODE space!
Time for some study of the so-called "bible" for the 8051:
www.lpcware.com/.../80c51-family-architecture
www.lpcware.com/.../80c51-family-programmers-guide-and-instruction-set
www.lpcware.com/.../80C51 Family Hardware Description.pdf
Thank you, those were some *very* useful links!
