I'm trying to write an usb cdc driver program. its cummunicate between pc and arduino due.actually my aim is reciveing the data form arduino and I read in visual c++ (command prompt).how to suppose i read the data in vc++. I don't the flow(sequence of the process) of cdc driver porgram . please explain me ?...........
You could look at HID application examples that Keil provides. Or it might be easier to communicate using RS232 program. Since there are several windows Visual C++ examples of that type of communication program.
I have decided to look into CDC programs also. So far it looks like ATMEL provides demos of ARM/AVR CDC programs. And PIC from Microchip has examples.
Found some code for PC and for a TI Board. processors.wiki.ti.com/.../USB_CDC_Benchmarking
I found out that the MCB2300 Board has a USBCDC program. Started looking at it. The way it looks is that the USBCDC is a virtual com port and requires a terminal program like teraterm to communicate with the port.
The test on the MCB2300 board uses two ports one is a uart port which is to pass characters to the Virtual com port it the uart receives characters. and the other way around.
I have not gotten it to work yet. Not sure about the actual baud rate of which UART Com port should be used.
Thank u for your continued support Mrs.Gary , Actually I have one doubt "Which one is easiest and most efficient way to create a USB CDC driver program , 'C++' or 'C#' ? "
Not really.
CDC is the USB Communications Device Class; Windows presents it (or part of it) to applications as a Virtual COM Port (VCP).
en.wikipedia.org/.../USB_communications_device_class
http://www.keil.com/pack/doc/mw/USB/html/_c_d_c.html
"requires a terminal program"
It doesn't specifically require a terminal program - though that's a good way to start experimenting
... 'C++' or 'C#' ?
Well, C# is a Microsoft language - only applicable to their .Net platforms.
So, presumably, this means that you're talking about the PC Host end - not the microcontroller end?
In which case, you don't need to create a Driver - because that is already provided by the Operating System.
Hi Andrew , still i'm confusing between USB CDC host and device program . Because i'm trying to send the ADC data from MCU(Arduino due) to pc . So i'm choosing USB CDC host program. because my MCU has a host.....so my question Why can't i choose USB CDC device program ?
If your MCU has a USB host it means it can communicate with USB devices.
But a PC is already a USB host in which case I can't understand why you want to try to run the embedded device as a host too - you think you can get two USB hosts to communicate?
