I need to use multiple Ethernet controllers within an enhancement to a project that currently runs TCPNet.
The only way I am sure I could accommodate multiple Ethernet controllers using TCPNet is to have two separate CPUs each with a single Ethernet controller. This is far from ideal but potentially feasible.
Does anyone know a way of running the TCPNet on multiple Ethernet controllers on a single CPU core? (I currently don't think it is possible, but if anyone has worked out a way I would appreciate the suggestion)
As an intermediate solution could this be done on a dual core chip instead, with the two cores running separate RTX OS and TCPNet? Any thoughts on the feasibility of this idea?
Thanks for any help.
