It's about the STM32F103 uC.
According the NVIC datasheet as I understand: - all uninitialized interrupts have their fixed default interrupt sequence number - by default initially all interrupts get priority number 0 (meaning highest priority) - if two uninitialized interrupts occur at the same time then the one with the lowest priority number is executed first - interrupts can be initialized by assigning them to a group (3,4,5,6,7) and to a subgroup within
With initialized/uninitialized is ment connected to a group or not.
My questions are:
- (I assume) interrupts assigned to a lower numbered group do pre-empty higher numbered group interrupts, is this correct?
- can a lower-priority uninitialized interrupt A get a higher priority than a higher-priority uninitialized interrupt B by connecting A to a group?
- if so: does A pre-empty B or does A wait for B to finish?
- will a higher-priority uninitialized interrupt pre-empty or wait for a lower-priority uninitialized interrupt?
I cannot figure this out from the NVIC pdf.
Henk
