Hello everybody, Wish you all a very happy new year.
I am facing a problem, I know basically it is a C language problem but I am still not able to catch up the language yet.
I have reversed the data pins of LCD. Now while programming I can reverse the data byte by byte, but the speed of the LCD is quite low.
void LCD_sendstring(unsigned char *strLCD){ // e.g. LCD_sendstring("LCD Tutorial"); while(*strLCD) //till string ends LCD_senddata(*strLCD++); //send characters one by one } void LCD_senddata(unsigned char var){ // e.g. LCD_senddata('A'); LCD_data = reverse(var); LCD_rs = 1; //Selected data register LCD_rw = 0; //We are writing LCD_en = 1; //Enable H-> LCD_en = 0; LCD_busy1(); //Wait for LCD to process the command }
As the above code reverses each character before sending to LCD, the characters appears slowly on LCD. So I am trying to reverse the whole string before sending to the LCD (LCD_senddata). I have tried the following codes but its not working.
void LCD_sendstring(unsigned char *strLCD){ // e.g. LCD_sendstring("LCD Tutorial"); reverse_string(strLCD); *strLCD = reverse_string1(strLCD); while(*strLCD) //till string ends LCD_senddata(*strLCD++); //send characters one by one } void LCD_senddata(unsigned char var){ // e.g. LCD_senddata('A'); LCD_data = var; LCD_rs = 1; //Selected data register LCD_rw = 0; //We are writing LCD_en = 1; //Enable H-> LCD_en = 0; LCD_busy1(); //Wait for LCD to process the command } void reverse_string(char *str){ //junk result while(*str){ // *str=reverse3(*str); *str='B'; str++; } str = &str; } char *reverse_string1(char *str){ //blank result int len = strlen(str); char *newstr = malloc(len+1); while(*str){ //till string ends // *newstr++ = reverse(*str++); // *newstr++ = *str++; *newstr++ = 'B'; } *newstr = '\0'; return newstr; }
In reverse_string I get junk result whereas in reverse_string1 I am getting blank display. Please Help!!!
