8bit reversal of all the bytes in a string
Hello everybody, Wish you all a very happy new year.
I am facing a problem, I know basically it is a C language problem but I am still not able to catch up the language yet.
I have reversed the data pins of LCD. Now while programming I can reverse the data byte by byte, but the speed of the LCD is quite low.
void LCD_sendstring(unsigned char *strLCD){     // e.g. LCD_sendstring("LCD Tutorial");
    while(*strLCD)                              //till string ends
        LCD_senddata(*strLCD++);                //send characters one by one
void LCD_senddata(unsigned char var){           // e.g. LCD_senddata('A');
    LCD_data = reverse(var);
    LCD_rs = 1;                 //Selected data register
    LCD_rw = 0;                 //We are writing
    LCD_en = 1;                 //Enable H->
    LCD_en = 0;
    LCD_busy1();                //Wait for LCD to process the command
As the above code reverses each character before sending to LCD, the characters appears slowly on LCD. So I am trying to reverse the whole string before sending to the LCD (LCD_senddata). I have tried the following codes but its not working.
     reverse_string(strLCD);
        *strLCD =  reverse_string1(strLCD);
    LCD_data = var;
    LCD_en = 0;
void reverse_string(char *str){ //junk result
        while(*str){
//              *str=reverse3(*str);
                *str='B';
                str++;
        str = &str;
char *reverse_string1(char *str){       //blank result
    int len = strlen(str);
        char *newstr = malloc(len+1);
        while(*str){                    //till string ends
//              *newstr++ = reverse(*str++);
//              *newstr++ = *str++;
                *newstr++ = 'B';
        *newstr = '\0';
    return newstr;
In reverse_string I get junk result whereas in reverse_string1 I am getting blank display. Please Help!!!
  • Your reverse_string() function has no need of any
    str = &str;
    Your reverse_string1() doesn't keep a pointer to the start of your allocated buffer - you instead return a pointer to the final '\0' character. So you get an empty printout.
    And your:
    Doesn't assign to a string pointer strLCD - but you assign a pointer value to a character position.
    There is zero reason to allocate any buffer - it's possible to do an in-place conversion unless the input parameter was a string constant. And even if you want to support printing of string constants, it's better to have a fixed buffer for your converted string data.
    str = &str;
    And your:
